2021-07-26 | validation: Add CallWithinISR() | Sebastian Huber | 1 | -0/+1 | |
Update #3269. | |||||
2021-07-26 | build: Remove superfluous library from rcxx01 | Sebastian Huber | 1 | -1/+0 | |
2021-07-15 | spcoverage: Remove test program | Sebastian Huber | 2 | -21/+0 | |
This program contained an optional test case. It was enabled by the RTEMS_COVERAGE define. The functions under test are not implemented by RTEMS. | |||||
2021-07-15 | build: Use BSP family for options | Chris Johns | 21 | -0/+21 | |
- Optionally add support for 'default-by-family' to allow option to be set by a family and so all related BSPs Close #4468 | |||||
2021-06-10 | splinkersets01: Test linker sets in library | Sebastian Huber | 3 | -2/+21 | |
Make sure that the linker sets work if placed in a library (this is how they are used in RTEMS). | |||||
2021-05-20 | testsuites: Remove telnetd01 | Vijay Kumar Banerjee | 2 | -24/+0 | |
telnetd01 test cannot be run without a network stack, so this test is being moved to the rtems-net-legacy repository. | |||||
2021-05-14 | validation: Add support library | Sebastian Huber | 4 | -4/+22 | |
Add a library for support functions used by validation tests. Rename tc-support.* to tx-support.* since this file does not contain test cases. | |||||
2021-04-13 | Revert "cpukit: Remove telnetd" | Vijay Kumar Banerjee | 2 | -0/+24 | |
This reverts commit 3299dda2454a8847c670a732f6c12ef1f2cc5dd0. | |||||
2021-04-07 | testsuites: Remove all legacy networking tests | Vijay Kumar Banerjee | 7 | -134/+0 | |
Update #3850 | |||||
2021-04-07 | cpukit: Remove telnetd | Vijay Kumar Banerjee | 2 | -24/+0 | |
2021-04-07 | testsuites/libtests: Remove networking01 | Vijay Kumar Banerjee | 1 | -21/+0 | |
2021-03-23 | validation: Add test case support functions | Sebastian Huber | 2 | -0/+2 | |
2021-03-16 | validation: Task create/construct | Sebastian Huber | 1 | -0/+2 | |
Run the task create/construct tests also on validation test suite 1 which has exactly one processor configured. | |||||
2021-03-11 | Test suite for FTW.H methods | Eshan dhawan | 2 | -0/+36 | |
Signed-off-by: Eshan Dhawan <eshandhawan51@gmail.com> | |||||
2021-03-01 | score: Fix _Stack_Extend_size() | Sebastian Huber | 1 | -0/+1 | |
Check for an integer overflow. Add a validation test for task create errors. | |||||
2021-02-24 | build: Sort source lists | Sebastian Huber | 84 | -596/+596 | |
Use the Python sorted() function to sort the "source" lists. | |||||
2021-02-20 | validation: Add signal manager tests | Sebastian Huber | 2 | -0/+4 | |
Update #4244. | |||||
2021-02-20 | validation: Add Validation1 test suite | Sebastian Huber | 2 | -0/+21 | |
2021-02-08 | validation: Tests for barrier manager | Sebastian Huber | 1 | -0/+4 | |
2021-02-08 | validation: Add tests for rtems_build_name() | Sebastian Huber | 1 | -0/+1 | |
2020-12-27 | libtests/ofw01: Added a test for RTEMS OFW | G S Niteesh Babu | 2 | -0/+23 | |
This commit adds a basic test that tests all the implemented RTEMS OFW functions. | |||||
2020-11-26 | config: CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE | Sebastian Huber | 2 | -0/+21 | |
In order to better support applications which use the new rtems_task_construct() directive add the CONFIGURE_INIT_TASK_CONSTURCT_STORAGE_SIZE configuration option. If this option is specified, then the Classic API initialization task is constructed with rtems_task_construct(). Update #4181. | |||||
2020-11-26 | Avoid INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL | Sebastian Huber | 2 | -21/+0 | |
Replace a runtime check with a compile time assertion. This makes the INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL obsolete. Update #4181. | |||||
2020-11-19 | config: Simplify task stack allocator init | Sebastian Huber | 2 | -21/+0 | |
Replace runtime checks with compile time assertions. This makes the INTERNAL_ERROR_BAD_STACK_HOOK obsolete. | |||||
2020-11-19 | validation/ts-performance-0: Add partition tests | Sebastian Huber | 1 | -0/+1 | |
2020-11-19 | validation/ts-performance-0: Add test suite | Sebastian Huber | 2 | -0/+21 | |
Share a default test suite with ts-validation-0. | |||||
2020-11-11 | dl06: Do not include loaded objs in base image | Sebastian Huber | 1 | -0/+1 | |
2020-10-12 | build: Fix format | Sebastian Huber | 1 | -1/+2 | |
2020-10-09 | testsuite/rcxx01: Add examples for use in the User manual | Chris Johns | 1 | -0/+3 | |
2020-10-08 | cpukit/librcxx: Add a C++ thread interface with attributes | Chris Johns | 2 | -0/+24 | |
2020-10-07 | Misc: Correct spelling of occurred | Joel Sherrill | 1 | -1/+1 | |
2020-10-02 | build: Fix typo | Sebastian Huber | 1 | -1/+1 | |
2020-10-01 | tests: Add and use <rtems/testopts.h> | Sebastian Huber | 3 | -0/+49 | |
Add the build option RTEMS_TEST_VERBOSITY to control the verbosity of test suites using the RTEMS Test Framework. | |||||
2020-10-01 | build: Fix build dependencies of JFFS2 tests | Sebastian Huber | 9 | -19/+19 | |
Close #4107. | |||||
2020-09-28 | validation: Test rtems_message_queue_construct() | Sebastian Huber | 1 | -0/+1 | |
Update #4007. | |||||
2020-09-17 | validation: rtems_task_construct() errors | Sebastian Huber | 1 | -0/+1 | |
This is the first test case generated from a specification item in the rtems-central repository. Update #3959. | |||||
2020-09-17 | validation: Add general purpose test suite | Sebastian Huber | 4 | -0/+56 | |
Add a general purpose test suite for validation tests. This is the first test suite generated from a specification item in the rtems-central repository. Update #3959. | |||||
2020-09-17 | CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE | Sebastian Huber | 2 | -0/+21 | |
Add this application configuration option. This configuration option can be used to reserve space for the dynamic linking of modules with thread-local storage objects. Add RTEMS_TASK_STORAGE_ALIGNMENT to define the minium alignment of a thread-local storage size. Update #4074. | |||||
2020-09-17 | build: Fix mghttpd01 test exclude | Sebastian Huber | 1 | -0/+1 | |
Update #3818. | |||||
2020-09-14 | irqs01/smpirqs01: New tests | Sebastian Huber | 4 | -0/+43 | |
Close #4034. | |||||
2020-09-14 | build: Use Python tarfile instead of pax | Sebastian Huber | 11 | -26/+10 | |
This patch is for the new build system. | |||||
2020-09-14 | build: Alternative build system based on waf | Sebastian Huber | 881 | -0/+20717 | |
Update #3818. |
