* | CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE | Sebastian Huber | 2020-09-17 | 2 | -0/+21 |
| | | | | | | | | | | | Add this application configuration option. This configuration option can be used to reserve space for the dynamic linking of modules with thread-local storage objects. Add RTEMS_TASK_STORAGE_ALIGNMENT to define the minium alignment of a thread-local storage size. Update #4074. | ||||
* | build: Fix mghttpd01 test exclude | Sebastian Huber | 2020-09-17 | 1 | -0/+1 |
| | | | | Update #3818. | ||||
* | irqs01/smpirqs01: New tests | Sebastian Huber | 2020-09-14 | 4 | -0/+43 |
| | | | | Close #4034. | ||||
* | build: Use Python tarfile instead of pax | Sebastian Huber | 2020-09-14 | 11 | -26/+10 |
| | | | | This patch is for the new build system. | ||||
* | build: Alternative build system based on waf | Sebastian Huber | 2020-09-14 | 881 | -0/+20717 |
Update #3818. |
