* | spcoverage: Remove test program | Sebastian Huber | 2021-07-15 | 2 | -21/+0 |
| | | | | | This program contained an optional test case. It was enabled by the RTEMS_COVERAGE define. The functions under test are not implemented by RTEMS. | ||||
* | build: Use BSP family for options | Chris Johns | 2021-07-15 | 21 | -0/+21 |
| | | | | | | | - Optionally add support for 'default-by-family' to allow option to be set by a family and so all related BSPs Close #4468 | ||||
* | splinkersets01: Test linker sets in library | Sebastian Huber | 2021-06-10 | 3 | -2/+21 |
| | | | | | Make sure that the linker sets work if placed in a library (this is how they are used in RTEMS). | ||||
* | testsuites: Remove telnetd01 | Vijay Kumar Banerjee | 2021-05-20 | 2 | -24/+0 |
| | | | | | telnetd01 test cannot be run without a network stack, so this test is being moved to the rtems-net-legacy repository. | ||||
* | validation: Add support library | Sebastian Huber | 2021-05-14 | 4 | -4/+22 |
| | | | | | | Add a library for support functions used by validation tests. Rename tc-support.* to tx-support.* since this file does not contain test cases. | ||||
* | Revert "cpukit: Remove telnetd" | Vijay Kumar Banerjee | 2021-04-13 | 2 | -0/+24 |
| | | | | This reverts commit 3299dda2454a8847c670a732f6c12ef1f2cc5dd0. | ||||
* | testsuites: Remove all legacy networking tests | Vijay Kumar Banerjee | 2021-04-07 | 7 | -134/+0 |
| | | | | Update #3850 | ||||
* | cpukit: Remove telnetd | Vijay Kumar Banerjee | 2021-04-07 | 2 | -24/+0 |
| | | | | Update #3850 | ||||
* | testsuites/libtests: Remove networking01 | Vijay Kumar Banerjee | 2021-04-07 | 1 | -21/+0 |
| | | | | Update #3850 | ||||
* | validation: Add test case support functions | Sebastian Huber | 2021-03-23 | 2 | -0/+2 |
* | validation: Task create/construct | Sebastian Huber | 2021-03-16 | 1 | -0/+2 |
| | | | | | Run the task create/construct tests also on validation test suite 1 which has exactly one processor configured. | ||||
* | Test suite for FTW.H methods | Eshan dhawan | 2021-03-11 | 2 | -0/+36 |
| | | | | Signed-off-by: Eshan Dhawan <eshandhawan51@gmail.com> | ||||
* | score: Fix _Stack_Extend_size() | Sebastian Huber | 2021-03-01 | 1 | -0/+1 |
| | | | | | Check for an integer overflow. Add a validation test for task create errors. | ||||
* | build: Sort source lists | Sebastian Huber | 2021-02-24 | 84 | -596/+596 |
| | | | | Use the Python sorted() function to sort the "source" lists. | ||||
* | validation: Add signal manager tests | Sebastian Huber | 2021-02-20 | 2 | -0/+4 |
| | | | | Update #4244. | ||||
* | validation: Add Validation1 test suite | Sebastian Huber | 2021-02-20 | 2 | -0/+21 |
* | validation: Tests for barrier manager | Sebastian Huber | 2021-02-08 | 1 | -0/+4 |
* | validation: Add tests for rtems_build_name() | Sebastian Huber | 2021-02-08 | 1 | -0/+1 |
* | libtests/ofw01: Added a test for RTEMS OFW | G S Niteesh Babu | 2020-12-27 | 2 | -0/+23 |
| | | | | | This commit adds a basic test that tests all the implemented RTEMS OFW functions. | ||||
* | config: CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE | Sebastian Huber | 2020-11-26 | 2 | -0/+21 |
| | | | | | | | | | | In order to better support applications which use the new rtems_task_construct() directive add the CONFIGURE_INIT_TASK_CONSTURCT_STORAGE_SIZE configuration option. If this option is specified, then the Classic API initialization task is constructed with rtems_task_construct(). Update #4181. | ||||
* | Avoid INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL | Sebastian Huber | 2020-11-26 | 2 | -21/+0 |
| | | | | | | | Replace a runtime check with a compile time assertion. This makes the INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL obsolete. Update #4181. | ||||
* | config: Simplify task stack allocator init | Sebastian Huber | 2020-11-19 | 2 | -21/+0 |
| | | | | | Replace runtime checks with compile time assertions. This makes the INTERNAL_ERROR_BAD_STACK_HOOK obsolete. | ||||
* | validation/ts-performance-0: Add partition tests | Sebastian Huber | 2020-11-19 | 1 | -0/+1 |
* | validation/ts-performance-0: Add test suite | Sebastian Huber | 2020-11-19 | 2 | -0/+21 |
| | | | | Share a default test suite with ts-validation-0. | ||||
* | dl06: Do not include loaded objs in base image | Sebastian Huber | 2020-11-11 | 1 | -0/+1 |
* | build: Fix format | Sebastian Huber | 2020-10-12 | 1 | -1/+2 |
* | testsuite/rcxx01: Add examples for use in the User manual | Chris Johns | 2020-10-09 | 1 | -0/+3 |
* | cpukit/librcxx: Add a C++ thread interface with attributes | Chris Johns | 2020-10-08 | 2 | -0/+24 |
* | Misc: Correct spelling of occurred | Joel Sherrill | 2020-10-07 | 1 | -1/+1 |
* | build: Fix typo | Sebastian Huber | 2020-10-02 | 1 | -1/+1 |
* | tests: Add and use <rtems/testopts.h> | Sebastian Huber | 2020-10-01 | 3 | -0/+49 |
| | | | | | Add the build option RTEMS_TEST_VERBOSITY to control the verbosity of test suites using the RTEMS Test Framework. | ||||
* | build: Fix build dependencies of JFFS2 tests | Sebastian Huber | 2020-10-01 | 9 | -19/+19 |
| | | | | Close #4107. | ||||
* | validation: Test rtems_message_queue_construct() | Sebastian Huber | 2020-09-28 | 1 | -0/+1 |
| | | | | Update #4007. | ||||
* | validation: rtems_task_construct() errors | Sebastian Huber | 2020-09-17 | 1 | -0/+1 |
| | | | | | | | This is the first test case generated from a specification item in the rtems-central repository. Update #3959. | ||||
* | validation: Add general purpose test suite | Sebastian Huber | 2020-09-17 | 4 | -0/+56 |
| | | | | | | | | | Add a general purpose test suite for validation tests. This is the first test suite generated from a specification item in the rtems-central repository. Update #3959. | ||||
* | CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE | Sebastian Huber | 2020-09-17 | 2 | -0/+21 |
| | | | | | | | | | | | Add this application configuration option. This configuration option can be used to reserve space for the dynamic linking of modules with thread-local storage objects. Add RTEMS_TASK_STORAGE_ALIGNMENT to define the minium alignment of a thread-local storage size. Update #4074. | ||||
* | build: Fix mghttpd01 test exclude | Sebastian Huber | 2020-09-17 | 1 | -0/+1 |
| | | | | Update #3818. | ||||
* | irqs01/smpirqs01: New tests | Sebastian Huber | 2020-09-14 | 4 | -0/+43 |
| | | | | Close #4034. | ||||
* | build: Use Python tarfile instead of pax | Sebastian Huber | 2020-09-14 | 11 | -26/+10 |
| | | | | This patch is for the new build system. | ||||
* | build: Alternative build system based on waf | Sebastian Huber | 2020-09-14 | 881 | -0/+20717 |
Update #3818. |
