2020-10-08 | cpukit/librcxx: Add a C++ thread interface with attributes | Chris Johns | 2 | -0/+24 | |
2020-10-07 | Misc: Correct spelling of occurred | Joel Sherrill | 1 | -1/+1 | |
2020-10-02 | build: Fix typo | Sebastian Huber | 1 | -1/+1 | |
2020-10-01 | tests: Add and use <rtems/testopts.h> | Sebastian Huber | 3 | -0/+49 | |
Add the build option RTEMS_TEST_VERBOSITY to control the verbosity of test suites using the RTEMS Test Framework. | |||||
2020-10-01 | build: Fix build dependencies of JFFS2 tests | Sebastian Huber | 9 | -19/+19 | |
Close #4107. | |||||
2020-09-28 | validation: Test rtems_message_queue_construct() | Sebastian Huber | 1 | -0/+1 | |
Update #4007. | |||||
2020-09-17 | validation: rtems_task_construct() errors | Sebastian Huber | 1 | -0/+1 | |
This is the first test case generated from a specification item in the rtems-central repository. Update #3959. | |||||
2020-09-17 | validation: Add general purpose test suite | Sebastian Huber | 4 | -0/+56 | |
Add a general purpose test suite for validation tests. This is the first test suite generated from a specification item in the rtems-central repository. Update #3959. | |||||
2020-09-17 | CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE | Sebastian Huber | 2 | -0/+21 | |
Add this application configuration option. This configuration option can be used to reserve space for the dynamic linking of modules with thread-local storage objects. Add RTEMS_TASK_STORAGE_ALIGNMENT to define the minium alignment of a thread-local storage size. Update #4074. | |||||
2020-09-17 | build: Fix mghttpd01 test exclude | Sebastian Huber | 1 | -0/+1 | |
Update #3818. | |||||
2020-09-14 | irqs01/smpirqs01: New tests | Sebastian Huber | 4 | -0/+43 | |
Close #4034. | |||||
2020-09-14 | build: Use Python tarfile instead of pax | Sebastian Huber | 11 | -26/+10 | |
This patch is for the new build system. | |||||
2020-09-14 | build: Alternative build system based on waf | Sebastian Huber | 881 | -0/+20717 | |
Update #3818. |
