* | testsuite: Add machine exception signal map test | Kinsey Moore | 2021-10-29 | 2 | -0/+24 |
| | | | | | Add a test to verify that mapping of machine exceptions to POSIX signals operates properly when the application requests it. | ||||
* | testsuite: Add machine exception resume test | Kinsey Moore | 2021-10-29 | 2 | -0/+22 |
| | | | | | Add a test to verify that intercepted exceptions can be resolved and execution can be resumed. | ||||
* | spec/libdebugger: Only enable for supported architectures | Chris Johns | 2021-10-22 | 1 | -3/+1 |
| | | | | Closes #4533 | ||||
* | Add support for IDLE Thread stack allocator | Joel Sherrill | 2021-10-11 | 3 | -0/+42 |
| | | | | | | | | Add a stack allocator hook specifically for allocation of IDLE thread stacks. This allows the user to decide if IDLE thread stacks are statically allocated or handled by the same custom allocator mechanism as other thread stacks. Closes #4524. | ||||
* | testsuites: Wrap putchar | Alex White | 2021-09-16 | 12 | -0/+12 |
| | | | | The linker flag to wrap putchar was lost in translation from make to waf. | ||||
* | confstr() support for RTEMS | Eshan dhawan | 2021-08-18 | 2 | -0/+22 |
| | | | | | | | | Closes #3373 confstr() style update Signed-off-by: Eshan Dhawan <eshandhawan51@gmail.com> | ||||
* | build: Merge default-by-family into by-variant | Sebastian Huber | 2021-08-18 | 21 | -21/+0 |
| | | | | | | | Prefix the BSP family name with "bsps/" to make it distinct to the BSP variant names. Update #4468. | ||||
* | validation: Test rtems_interrupt_handler_iterate() | Sebastian Huber | 2021-07-26 | 1 | -0/+1 |
| | | | | Update #3269. | ||||
* | validation: Test rtems_interrupt_set_affinity() | Sebastian Huber | 2021-07-26 | 1 | -0/+1 |
* | validation: Test rtems_interrupt_get_affinity() | Sebastian Huber | 2021-07-26 | 1 | -0/+1 |
* | validation: Test rtems_interrupt_raise_on() | Sebastian Huber | 2021-07-26 | 1 | -0/+1 |
* | validation: Test rtems_interrupt_is_pending() | Sebastian Huber | 2021-07-26 | 1 | -0/+1 |
* | validation: Test rtems_interrupt_clear() | Sebastian Huber | 2021-07-26 | 1 | -0/+1 |
* | validation: Test rtems_interrupt_raise() | Sebastian Huber | 2021-07-26 | 1 | -0/+1 |
* | validation: Test rtems_interrupt_entry_remove() | Sebastian Huber | 2021-07-26 | 1 | -0/+1 |
* | validation: Test rtems_interrupt_entry_install() | Sebastian Huber | 2021-07-26 | 1 | -0/+1 |
* | validation: Test rtems_interrupt_vector_disable() | Sebastian Huber | 2021-07-26 | 1 | -0/+1 |
* | validation: Test rtems_interrupt_vector_enable() | Sebastian Huber | 2021-07-26 | 1 | -0/+1 |
* | validation: rtems_interrupt_vector_is_enabled() | Sebastian Huber | 2021-07-26 | 1 | -0/+1 |
* | validation: Test rtems_interrupt_get_attributes() | Sebastian Huber | 2021-07-26 | 1 | -0/+1 |
* | validation: HasInterruptVectorEntriesInstalled() | Sebastian Huber | 2021-07-26 | 1 | -0/+1 |
* | validation: Add CallWithinISR() | Sebastian Huber | 2021-07-26 | 1 | -0/+1 |
* | build: Remove superfluous library from rcxx01 | Sebastian Huber | 2021-07-26 | 1 | -1/+0 |
* | spcoverage: Remove test program | Sebastian Huber | 2021-07-15 | 2 | -21/+0 |
| | | | | | This program contained an optional test case. It was enabled by the RTEMS_COVERAGE define. The functions under test are not implemented by RTEMS. | ||||
* | build: Use BSP family for options | Chris Johns | 2021-07-15 | 21 | -0/+21 |
| | | | | | | | - Optionally add support for 'default-by-family' to allow option to be set by a family and so all related BSPs Close #4468 | ||||
* | splinkersets01: Test linker sets in library | Sebastian Huber | 2021-06-10 | 3 | -2/+21 |
| | | | | | Make sure that the linker sets work if placed in a library (this is how they are used in RTEMS). | ||||
* | testsuites: Remove telnetd01 | Vijay Kumar Banerjee | 2021-05-20 | 2 | -24/+0 |
| | | | | | telnetd01 test cannot be run without a network stack, so this test is being moved to the rtems-net-legacy repository. | ||||
* | validation: Add support library | Sebastian Huber | 2021-05-14 | 4 | -4/+22 |
| | | | | | | Add a library for support functions used by validation tests. Rename tc-support.* to tx-support.* since this file does not contain test cases. | ||||
* | Revert "cpukit: Remove telnetd" | Vijay Kumar Banerjee | 2021-04-13 | 2 | -0/+24 |
| | | | | This reverts commit 3299dda2454a8847c670a732f6c12ef1f2cc5dd0. | ||||
* | testsuites: Remove all legacy networking tests | Vijay Kumar Banerjee | 2021-04-07 | 7 | -134/+0 |
| | | | | Update #3850 | ||||
* | cpukit: Remove telnetd | Vijay Kumar Banerjee | 2021-04-07 | 2 | -24/+0 |
| | | | | Update #3850 | ||||
* | testsuites/libtests: Remove networking01 | Vijay Kumar Banerjee | 2021-04-07 | 1 | -21/+0 |
| | | | | Update #3850 | ||||
* | validation: Add test case support functions | Sebastian Huber | 2021-03-23 | 2 | -0/+2 |
* | validation: Task create/construct | Sebastian Huber | 2021-03-16 | 1 | -0/+2 |
| | | | | | Run the task create/construct tests also on validation test suite 1 which has exactly one processor configured. | ||||
* | Test suite for FTW.H methods | Eshan dhawan | 2021-03-11 | 2 | -0/+36 |
* | score: Fix _Stack_Extend_size() | Sebastian Huber | 2021-03-01 | 1 | -0/+1 |
| | | | | | Check for an integer overflow. Add a validation test for task create errors. | ||||
* | build: Sort source lists | Sebastian Huber | 2021-02-24 | 84 | -596/+596 |
| | | | | Use the Python sorted() function to sort the "source" lists. | ||||
* | validation: Add signal manager tests | Sebastian Huber | 2021-02-20 | 2 | -0/+4 |
| | | | | Update #4244. | ||||
* | validation: Add Validation1 test suite | Sebastian Huber | 2021-02-20 | 2 | -0/+21 |
* | validation: Tests for barrier manager | Sebastian Huber | 2021-02-08 | 1 | -0/+4 |
* | validation: Add tests for rtems_build_name() | Sebastian Huber | 2021-02-08 | 1 | -0/+1 |
* | libtests/ofw01: Added a test for RTEMS OFW | G S Niteesh Babu | 2020-12-27 | 2 | -0/+23 |
| | | | | | This commit adds a basic test that tests all the implemented RTEMS OFW functions. | ||||
* | config: CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE | Sebastian Huber | 2020-11-26 | 2 | -0/+21 |
| | | | | | | | | | | In order to better support applications which use the new rtems_task_construct() directive add the CONFIGURE_INIT_TASK_CONSTURCT_STORAGE_SIZE configuration option. If this option is specified, then the Classic API initialization task is constructed with rtems_task_construct(). Update #4181. | ||||
* | Avoid INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL | Sebastian Huber | 2020-11-26 | 2 | -21/+0 |
| | | | | | | | Replace a runtime check with a compile time assertion. This makes the INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL obsolete. Update #4181. | ||||
* | config: Simplify task stack allocator init | Sebastian Huber | 2020-11-19 | 2 | -21/+0 |
| | | | | | Replace runtime checks with compile time assertions. This makes the INTERNAL_ERROR_BAD_STACK_HOOK obsolete. | ||||
* | validation/ts-performance-0: Add partition tests | Sebastian Huber | 2020-11-19 | 1 | -0/+1 |
* | validation/ts-performance-0: Add test suite | Sebastian Huber | 2020-11-19 | 2 | -0/+21 |
| | | | | Share a default test suite with ts-validation-0. | ||||
* | dl06: Do not include loaded objs in base image | Sebastian Huber | 2020-11-11 | 1 | -0/+1 |
* | build: Fix format | Sebastian Huber | 2020-10-12 | 1 | -1/+2 |
* | testsuite/rcxx01: Add examples for use in the User manual | Chris Johns | 2020-10-09 | 1 | -0/+3 |
