2021-07-26 | validation: Test rtems_interrupt_is_pending() | Sebastian Huber | 1 | -0/+1 | |
Update #3269. | |||||
2021-07-26 | validation: Test rtems_interrupt_clear() | Sebastian Huber | 1 | -0/+1 | |
2021-07-26 | validation: Test rtems_interrupt_raise() | Sebastian Huber | 1 | -0/+1 | |
2021-07-26 | validation: Test rtems_interrupt_entry_remove() | Sebastian Huber | 1 | -0/+1 | |
2021-07-26 | validation: Test rtems_interrupt_entry_install() | Sebastian Huber | 1 | -0/+1 | |
2021-07-26 | validation: Test rtems_interrupt_vector_disable() | Sebastian Huber | 1 | -0/+1 | |
2021-07-26 | validation: Test rtems_interrupt_vector_enable() | Sebastian Huber | 1 | -0/+1 | |
2021-07-26 | validation: rtems_interrupt_vector_is_enabled() | Sebastian Huber | 1 | -0/+1 | |
2021-07-26 | validation: Test rtems_interrupt_get_attributes() | Sebastian Huber | 1 | -0/+1 | |
2021-07-26 | validation: HasInterruptVectorEntriesInstalled() | Sebastian Huber | 1 | -0/+1 | |
2021-07-26 | validation: Add CallWithinISR() | Sebastian Huber | 1 | -0/+1 | |
2021-05-14 | validation: Add support library | Sebastian Huber | 4 | -4/+22 | |
Add a library for support functions used by validation tests. Rename tc-support.* to tx-support.* since this file does not contain test cases. | |||||
2021-03-23 | validation: Add test case support functions | Sebastian Huber | 2 | -0/+2 | |
2021-03-16 | validation: Task create/construct | Sebastian Huber | 1 | -0/+2 | |
Run the task create/construct tests also on validation test suite 1 which has exactly one processor configured. | |||||
2021-03-01 | score: Fix _Stack_Extend_size() | Sebastian Huber | 1 | -0/+1 | |
Check for an integer overflow. Add a validation test for task create errors. | |||||
2021-02-20 | validation: Add signal manager tests | Sebastian Huber | 2 | -0/+4 | |
Update #4244. | |||||
2021-02-20 | validation: Add Validation1 test suite | Sebastian Huber | 2 | -0/+21 | |
2021-02-08 | validation: Tests for barrier manager | Sebastian Huber | 1 | -0/+4 | |
2021-02-08 | validation: Add tests for rtems_build_name() | Sebastian Huber | 1 | -0/+1 | |
2020-11-19 | validation/ts-performance-0: Add partition tests | Sebastian Huber | 1 | -0/+1 | |
2020-11-19 | validation/ts-performance-0: Add test suite | Sebastian Huber | 2 | -0/+21 | |
Share a default test suite with ts-validation-0. | |||||
2020-09-28 | validation: Test rtems_message_queue_construct() | Sebastian Huber | 1 | -0/+1 | |
Update #4007. | |||||
2020-09-17 | validation: rtems_task_construct() errors | Sebastian Huber | 1 | -0/+1 | |
This is the first test case generated from a specification item in the rtems-central repository. Update #3959. | |||||
2020-09-17 | validation: Add general purpose test suite | Sebastian Huber | 2 | -0/+37 | |
Add a general purpose test suite for validation tests. This is the first test suite generated from a specification item in the rtems-central repository. Update #3959. |
