* | score: Fix _Stack_Extend_size() | Sebastian Huber | 2021-03-01 | 1 | -0/+1 |
| | | | | | Check for an integer overflow. Add a validation test for task create errors. | ||||
* | validation: Add signal manager tests | Sebastian Huber | 2021-02-20 | 2 | -0/+4 |
| | | | | Update #4244. | ||||
* | validation: Add Validation1 test suite | Sebastian Huber | 2021-02-20 | 2 | -0/+21 |
* | validation: Tests for barrier manager | Sebastian Huber | 2021-02-08 | 1 | -0/+4 |
* | validation: Add tests for rtems_build_name() | Sebastian Huber | 2021-02-08 | 1 | -0/+1 |
* | validation/ts-performance-0: Add partition tests | Sebastian Huber | 2020-11-19 | 1 | -0/+1 |
* | validation/ts-performance-0: Add test suite | Sebastian Huber | 2020-11-19 | 2 | -0/+21 |
| | | | | Share a default test suite with ts-validation-0. | ||||
* | validation: Test rtems_message_queue_construct() | Sebastian Huber | 2020-09-28 | 1 | -0/+1 |
| | | | | Update #4007. | ||||
* | validation: rtems_task_construct() errors | Sebastian Huber | 2020-09-17 | 1 | -0/+1 |
| | | | | | | | This is the first test case generated from a specification item in the rtems-central repository. Update #3959. | ||||
* | validation: Add general purpose test suite | Sebastian Huber | 2020-09-17 | 2 | -0/+37 |
Add a general purpose test suite for validation tests. This is the first test suite generated from a specification item in the rtems-central repository. Update #3959. |
