path: root/spec/build/testsuites/validation/fatal-mandatory-processor-not-present.yml (follow)
* validation: Add system termination test suitesSebastian Huber2022-03-241-0/+20
The test source code is generated from specification items by the "./spec2modules.py" script contained in the git://git.rtems.org/rtems-central.git Git repository. Please read the "How-To" section in the "Software Requirements Engineering" chapter of the RTEMS Software Engineering manual to get more information about the process. Update #3716.
