2023-05-20 | Update company name | Sebastian Huber | 1 | -1/+1 | |
The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | |||||
2022-10-14 | score: INTERNAL_ERROR_IDLE_THREAD_STACK_TOO_SMALL | Sebastian Huber | 1 | -3/+3 | |
Ensure that the IDLE storage allocator did allocate a suffiently large area. Update #3835. Update #4524. | |||||
2022-10-14 | score: INTERNAL_ERROR_IDLE_THREAD_CREATE_FAILED | Sebastian Huber | 1 | -2/+3 | |
Add the INTERNAL_ERROR_IDLE_THREAD_CREATE_FAILED fatal error in case the creation of an idle thread fails. This may happen due to a failing create extension provided by the application. | |||||
2022-02-21 | kern_ntptime.c: Port to RTEMS | Sebastian Huber | 1 | -3/+3 | |
Remove previous adjtime() implementation. Update #2348. | |||||
2020-09-14 | build: Alternative build system based on waf | Sebastian Huber | 1 | -0/+19 | |
Update #3818. |
