Enable an individual testsuite only through the corresponding enable.
Use BUILD_TESTS to change the default value of the individual testsuite
enable options. This allows the user to enable all testsuites with
specific exceptions.
For example, this builds all testsuites except the benchmarks:
[arch/bsp]
BUILD_TESTS = True
BUILD_BENCHMARKS = False
brains GmbH.
Propagate the group defined cppflags, cflags, and cxxflags from parent groups
to child items through the build item context.
Update #4670.
The linker flag to wrap putchar was lost in translation from make to waf.
Use the Python sorted() function to sort the "source" lists.
Update #3818.
