Update #2349.
Remove previous adjtime() implementation.
Update #2348.
GCC versions prior to 6.1 used a RTEMS thread model based on
rtems_gxx_*() functions. GCC version 6.1 or later uses the
self-contained synchronization objects of Newlib <sys/lock.h> for the
RTEMS thread model.
Remove the obsolete implementation.
Close #3143.
Add a test to verify that intercepted exceptions can be resolved and
execution can be resumed.
Add a stack allocator hook specifically for allocation of IDLE thread stacks.
This allows the user to decide if IDLE thread stacks are statically allocated
or handled by the same custom allocator mechanism as other thread stacks.
Closes #4524.
The linker flag to wrap putchar was lost in translation from make to waf.
This program contained an optional test case. It was enabled by the
RTEMS_COVERAGE define. The functions under test are not implemented by RTEMS.
Make sure that the linker sets work if placed in a library (this is how
they are used in RTEMS).
Use the Python sorted() function to sort the "source" lists.
In order to better support applications which use the new
rtems_task_construct() directive add the
CONFIGURE_INIT_TASK_CONSTURCT_STORAGE_SIZE configuration option. If
this option is specified, then the Classic API initialization task is
constructed with rtems_task_construct().
Update #4181.
Replace a runtime check with a compile time assertion. This makes the
INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL obsolete.
Update #4181.
Replace runtime checks with compile time assertions. This makes the
INTERNAL_ERROR_BAD_STACK_HOOK obsolete.
Add this application configuration option. This configuration option can be
used to reserve space for the dynamic linking of modules with thread-local
storage objects.
Add RTEMS_TASK_STORAGE_ALIGNMENT to define the minium alignment of a
thread-local storage size.
Update #4074.
Update #3818.
