path: root/spec/build/testsuites/sptests/spfatal34.yml (follow)
* config: CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZESebastian Huber2020-11-261-0/+19
In order to better support applications which use the new rtems_task_construct() directive add the CONFIGURE_INIT_TASK_CONSTURCT_STORAGE_SIZE configuration option. If this option is specified, then the Classic API initialization task is constructed with rtems_task_construct(). Update #4181.
