2020-11-26 | config: CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE | Sebastian Huber | 1 | -2/+2 | |
In order to better support applications which use the new rtems_task_construct() directive add the CONFIGURE_INIT_TASK_CONSTURCT_STORAGE_SIZE configuration option. If this option is specified, then the Classic API initialization task is constructed with rtems_task_construct(). Update #4181. | |||||
2020-09-14 | build: Alternative build system based on waf | Sebastian Huber | 1 | -0/+19 | |
Update #3818. |
