2022-01-27 | Remove obsolete rtems_gxx_*() implementation | Sebastian Huber | 1 | -19/+0 | |
GCC versions prior to 6.1 used a RTEMS thread model based on rtems_gxx_*() functions. GCC version 6.1 or later uses the self-contained synchronization objects of Newlib <sys/lock.h> for the RTEMS thread model. Remove the obsolete implementation. Close #3143. | |||||
2020-09-14 | build: Alternative build system based on waf | Sebastian Huber | 1 | -0/+19 | |
Update #3818. |
