* | testsuites: Remove telnetd01 | Vijay Kumar Banerjee | 2021-05-20 | 1 | -2/+0 |
| | | | | | telnetd01 test cannot be run without a network stack, so this test is being moved to the rtems-net-legacy repository. | ||||
* | Revert "cpukit: Remove telnetd" | Vijay Kumar Banerjee | 2021-04-13 | 1 | -0/+2 |
| | | | | This reverts commit 3299dda2454a8847c670a732f6c12ef1f2cc5dd0. | ||||
* | testsuites: Remove all legacy networking tests | Vijay Kumar Banerjee | 2021-04-07 | 1 | -8/+0 |
| | | | | Update #3850 | ||||
* | cpukit: Remove telnetd | Vijay Kumar Banerjee | 2021-04-07 | 1 | -2/+0 |
| | | | | Update #3850 | ||||
* | libtests/ofw01: Added a test for RTEMS OFW | G S Niteesh Babu | 2020-12-27 | 1 | -0/+2 |
| | | | | | This commit adds a basic test that tests all the implemented RTEMS OFW functions. | ||||
* | cpukit/librcxx: Add a C++ thread interface with attributes | Chris Johns | 2020-10-08 | 1 | -0/+2 |
* | irqs01/smpirqs01: New tests | Sebastian Huber | 2020-09-14 | 1 | -0/+2 |
| | | | | Close #4034. | ||||
* | build: Use Python tarfile instead of pax | Sebastian Huber | 2020-09-14 | 1 | -2/+0 |
| | | | | This patch is for the new build system. | ||||
* | build: Alternative build system based on waf | Sebastian Huber | 2020-09-14 | 1 | -0/+320 |
Update #3818. |
