2020-10-01 | tests: Add and use <rtems/testopts.h> | Sebastian Huber | 1 | -0/+2 | |
Add the build option RTEMS_TEST_VERBOSITY to control the verbosity of test suites using the RTEMS Test Framework. | |||||
2020-09-17 | validation: Add general purpose test suite | Sebastian Huber | 1 | -0/+4 | |
Add a general purpose test suite for validation tests. This is the first test suite generated from a specification item in the rtems-central repository. Update #3959. | |||||
2020-09-14 | build: Alternative build system based on waf | Sebastian Huber | 1 | -0/+65 | |
Update #3818. |
