The Autoconf/Automake build system did something similar. This fixes
the build of sigprogmask.c which uses RTEMS_POSIX_API and expects to get
it defined via "config.h".
Update #3818.
In contrast to message queues created by rtems_message_queue_create(), the
message queues constructed by this directive use a user-provided message buffer
storage area.
Add RTEMS_MESSAGE_QUEUE_BUFFER() to define a message buffer type for message
buffer storage areas.
Update #4007.
Move the CORE_message_queue_Buffer definition to a separate header file to be
able to use it independent of the remaining Message Queue Handler API.
Change license to BSD-2-Clause according to file history.
Update #3053.
Update #4007.
Update #3818.
Update #3053.
Provide the default trace data in a separate file to avoid issues on targets
with a small-data area.
Close #3883.
In contrast to rtems_task_create() this function constructs a task with
a user-provided task storage area. The new directive uses a
configuration structure instead of individual parameters.
Add RTEMS_TASK_STORAGE_SIZE() to calculate the recommended size of a
task storage area based on the task attributes and the size dedicated to
the task stack and thread-local storage. This macro may allow future
extensions without breaking the API.
Add application configuration option
CONFIGURE_MINIMUM_TASKS_WITH_USER_PROVIDED_STORAGE to adjust RTEMS
Workspace size estimate.
Update #3959.
Update #3818.
