2021-02-24 | build: Sort source lists | Sebastian Huber | 1 | -12/+12 | |
Use the Python sorted() function to sort the "source" lists. | |||||
2020-11-19 | libtest: Add primitive test case memory allocator | Sebastian Huber | 1 | -0/+1 | |
This primitive test case memory allocator uses memory from the low-level memory information provided by the BSP. At the beginning of each test case, the memory available to the test case is reinitialized. This allows the use of a simple allocate only allocator. | |||||
2020-11-19 | libtest: Make test case allocator configurable | Sebastian Huber | 1 | -1/+0 | |
2020-09-14 | build: Alternative build system based on waf | Sebastian Huber | 1 | -0/+39 | |
Update #3818. |
