path: root/spec/build/cpukit/cfghdr.yml (follow)
* build: Include cpuopts.h in "config.h"Sebastian Huber2020-09-301-1/+2
| | | | | | | | The Autoconf/Automake build system did something similar. This fixes the build of sigprogmask.c which uses RTEMS_POSIX_API and expects to get it defined via "config.h". Update #3818.
* build: Alternative build system based on wafSebastian Huber2020-09-141-0/+69
Update #3818.
