Update #4372
Updates #4321
The following files have been ported
1) ti_pinmux.c
2) ti_pinmux.h
3) am335x_scm_padconf.c
4) am335x_scm_padconf.h
Update #3784
Detects the SOC type using FDT and also replaces the ti_cpuid.h
header in FreeBSD with custom one.
Moves drvmgr_drivers[] from amba.c to a separate file in order
to avoid the dependecy on APBUART/GPTIMER drivers. This has
an effect when user configured not to use timer or uart
in their project.
Close #4324.
Update #4324.
Reimplemented the baud-rate algorithm from scratch to cope with
GRCAN, GRCANFD and OC_CAN devices.
Update #4323.
Updates #4320
This enables several testsuites that were initially disabled during
development.
The current ZynqMP BSPs don't have _qemu in their name as do all other
RTEMS BSPs that are specifically made to run on QEMU. This fixes the
naming for those ZynqMP BSP variants for easier identification.
AArch64 on hardware is often started at EL2 instead of EL1 from either
u-boot or a first stage bootloader. This allows RTEMS to drop from EL2
execution to EL1 to operate as normal.
Remove usage of SUBALIGN() in aarch64 linkcmds which works around a
difference in behavior on AArch64 platforms. This is no longer necessary
since alignment is now enforced explicitly.
Closes #4178.
Closes #4179.
Update #4267.
Update #4267.
Use the Python sorted() function to sort the "source" lists.
Update #4244.
- Add support to the BSP to enable irq-generic management
- Update the powerpc shared irq code to support irq-generic. This
is an opt in option for existing powerpc bsps. This change
should be simpler now
- Fix a number of issues in ISA IRQ controller handling by porting
fixes from the i386 (PC) BSP
Closes #4238
Closes #4239
Sort alphabetically.
GCC 11 uses DWARF 5 by default.
Move the Freescale EDMA driver to it's own object and build it only for
the BSP that is currently using it.
This allows an application to get the registers of the LPSPI. That is
usefull for applications that want to use DMA for a very specialized and
highly optimized communication.
Update #4180
Note: The changes have been done with portability in mind. The driver
should (in theory) be able to replace the original one in the MPC BSPs
too. For full compatibility an adaption layer and especially a test
would be necessary. Because both are missing, don't integrate it into
the MPC BSP now.
Update #4180
This allows applications to individually provide configuration
structures.
Update #4209.
structures.
Update #4209.
RTEMS OFW is a FDT only implementation of the OpenFirmWare
interface. This API is created to be compatible with FreeBSD
OpenFirmWare interface. The main intention is to make
porting of FreeBSD drivers to RTEMS easier.
Most functions implemented have an direct one-one mapping
with the original OFW API and some extra auxiliary functions
were implemented to make working with device trees easier in
RTEMS.
Update #3784
This BSP supports the Arm Fixed Virtual Platform. Only the Cortex-R52
processor configuration is supported by the BSP. It should be easy to
add support for other variants if needed.
Update #4202.
This avoids a function call overhead in the interrupt dispatching.
Update #4202.
Set the VBAR to the vector table in the start section before
bsp_start_hook_0() is called to earlier handle exceptions in RTEMS.
Set the VBAR to the normal vector table in start.S for the main
processor. Secondary processors set it in bsp_start_hook_0().
Update #4202.
When moving the headers from the imx BSP to the shared area, the wrong
directory has been selected. This patch fixes that problem.
Update #4180
This allows simpler creation of own dts files for custom boards.
Update #4180
- Disabled by default
- Enable using ARM_MMU_USE_SMALL_PAGES option
Close 4192.
Clarify documentation.
Update #4202.
Update #4202.
Update #4202.
Currently, zynq-uart code is always built and has some requirements for
BSPs that use it. Instead of making all BSPs satisfy that requirement or
working around it by setting defaults, this moves the zynq-uart code
into its own spec build object so it can be included if needed.
The option for defining the console minor should be an integer, not a
boolean.
This adds a BSP family that runs on the Xilinx Ultrascale+ MPSOC
(ZynqMP) family of chips. It is configured to be usable on the Qemu
ZCU102 machine definition and should be almost trivially portable to
ZynqMP development boards and custom hardware. It is also configured to
be usable with libbsd.
