path: root/spec/build/bsps/sparc/objmem.yml (follow)
* libc: Optimize malloc() initializationSebastian Huber2021-11-301-0/+1
| | | | | | | | | | | | | | | | The BSPs provide memory for the separate C Program Heap initialization via _Memory_Get(). Most BSPs provide exactly one memory area. Only two BSPs provide more than one memory area (arm/altera-cyclone-v and bsps/powerpc/mpc55xxevb). Only if more than one memory area is provided, there is a need to use _Heap_Extend(). Provide two implementations to initialize the separate C Program Heap and let the BSP select one of the implementations based on the number of provided memory areas. This gets rid of a dependency on _Heap_Extend(). It also avoids dead code sections for most BSPs. Change licence to BSD-2-Clause according to file history. Update #3053.
* score: Optimize Workspace Handler initializationSebastian Huber2021-11-301-0/+1
| | | | | | | | | | | | The BSPs provide memory for the workspace initialization via _Memory_Get(). Most BSPs provide exactly one memory area. Only two BSPs provide more than one memory area (arm/altera-cyclone-v and bsps/powerpc/mpc55xxevb). Only if more than one memory area is provided, there is a need to use _Heap_Extend(). Provide two implementations to initialize the workspace handler and let the BSP select one of the implementations based on the number of provided memory areas. This gets rid of a dependency on _Heap_Extend(). It also avoids dead code sections for most BSPs.
* build: Use common objects item for get memorySebastian Huber2021-11-301-0/+14
