path: root/spec/build/bsps/sparc/leon3 (follow)
* build: Use common objects item for get memorySebastian Huber2021-11-302-1/+2
* build: Merge default-by-family into by-variantSebastian Huber2021-08-185-5/+0
| | | | | | | Prefix the BSP family name with "bsps/" to make it distinct to the BSP variant names. Update #4468.
* build: Use BSP family for optionsChris Johns2021-07-155-0/+5
| | | | | | | - Optionally add support for 'default-by-family' to allow option to be set by a family and so all related BSPs Close #4468
* sparc: More reliable bad trap handlingSebastian Huber2021-06-241-1/+0
| | | | | | | | | | | | | Statically initialize the trap table in start.S to jump to _SPARC_Bad_trap() for all unexpected traps. This enables a proper RTEMS fatal error handling right from the start. Do not rely on the stack and register settings which caused an unexpected trap. Use the ISR stack of the processor to do the fatal error handling. Save the full context which caused the trap. Fatal error handler may use it for error logging. Unify the _CPU_Exception_frame_print() implementations and move it to cpukit. Update #4459.
* bsps: Remove networking driversVijay Kumar Banerjee2021-04-071-18/+0
| | | | Update #3850
* spec: Remove RTEMS_NETWORKING optionsVijay Kumar Banerjee2021-04-072-21/+0
| | | | Update #3850
* leon3: avoid dependency on apbuart/timer driverDaniel Hellstrom2021-03-111-0/+1
| | | | | | | Moves drvmgr_drivers[] from amba.c to a separate file in order to avoid the dependecy on APBUART/GPTIMER drivers. This has an effect when user configured not to use timer or uart in their project.
* bsps: Add default rtems_get_target_hash()Sebastian Huber2021-02-261-0/+1
| | | | Update #4267.
* build: Alternative build system based on wafSebastian Huber2020-09-1416-0/+386
Update #3818.
