* | build: Merge default-by-family into by-variant | Sebastian Huber | 2021-08-18 | 3 | -3/+0 |
| | | | | | | | Prefix the BSP family name with "bsps/" to make it distinct to the BSP variant names. Update #4468. | ||||
* | build: Use BSP family for options | Chris Johns | 2021-07-15 | 3 | -0/+3 |
| | | | | | | | - Optionally add support for 'default-by-family' to allow option to be set by a family and so all related BSPs Close #4468 | ||||
* | sparc: More reliable bad trap handling | Sebastian Huber | 2021-06-24 | 1 | -1/+0 |
| | | | | | | | | | | | | | Statically initialize the trap table in start.S to jump to _SPARC_Bad_trap() for all unexpected traps. This enables a proper RTEMS fatal error handling right from the start. Do not rely on the stack and register settings which caused an unexpected trap. Use the ISR stack of the processor to do the fatal error handling. Save the full context which caused the trap. Fatal error handler may use it for error logging. Unify the _CPU_Exception_frame_print() implementations and move it to cpukit. Update #4459. | ||||
* | spec: Remove RTEMS_NETWORKING options | Vijay Kumar Banerjee | 2021-04-07 | 2 | -18/+0 |
| | | | | Update #3850 | ||||
* | bsps: Add default rtems_get_target_hash() | Sebastian Huber | 2021-02-26 | 1 | -0/+1 |
| | | | | Update #4267. | ||||
* | build: Alternative build system based on waf | Sebastian Huber | 2020-09-14 | 6 | -0/+155 |
Update #3818. |
