Enable a BSP-specific CPU counter implementation.
Update #4954.
Remove the BSP_POWER_DOWN_AT_FATAL_HALT BSP option. Applications should
do the customization of the system termination with an initial fatal
extension.
brains GmbH.
Updates #4705
Statically initialize the trap table in start.S to jump to _SPARC_Bad_trap()
for all unexpected traps. This enables a proper RTEMS fatal error handling
right from the start. Do not rely on the stack and register settings which
caused an unexpected trap. Use the ISR stack of the processor to do the fatal
error handling. Save the full context which caused the trap. Fatal error
handler may use it for error logging.
Unify the _CPU_Exception_frame_print() implementations and move it to cpukit.
Update #4459.
Update #3850
Update #4267.
Update #3818.
