path: root/spec/build/bsps/sh/shsim (unfollow)
2023-05-20Update company nameSebastian Huber14-14/+14
The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH.
2023-01-17build: Use enabled by for defaultsSebastian Huber7-24/+20
Merge the "default" and "default-by-variant" attributes. Use an "enabled-by" expression to select the default value based on the enabled set. This makes it possible to select default values depending on other options. For example you could choose memory settings based on whether RTEMS_SMP is enabled or disabled. The change was tested by comparing the output of ./waf bspdefaults before and after the change.
2023-01-17build: Add reason to test state definitionsSebastian Huber4-32/+44
2022-08-22spec/bsps: Do not install tm27.hChris Johns1-1/+0
Updates #4705
2022-07-04build: Add cppflags, cflags, cxxflags to groupsSebastian Huber1-0/+3
Propagate the group defined cppflags, cflags, and cxxflags from parent groups to child items through the build item context. Update #4670.
2022-03-24validation: Add test suitesSebastian Huber4-0/+4
The test source code is generated from specification items by the "./spec2modules.py" script contained in the git://git.rtems.org/rtems-central.git Git repository. Please read the "How-To" section in the "Software Requirements Engineering" chapter of the RTEMS Software Engineering manual to get more information about the process. Update #3716.
2022-03-23build: Exclude rcxx01 test for sh BSPsSebastian Huber4-0/+4
There seems to be a code size increase with GCC 12.
2022-01-15bsps: Default to CPU counter benchmark timerSebastian Huber1-1/+1
Most BSPs which used the stubbed benachmark timer provide a CPU counter. All BSPs provide at least a stub CPU counter. Simply use the benchmark timer implementation using the CPU counter.
2021-11-30build: Use common objects item for get memorySebastian Huber2-1/+2
2021-08-18build: Merge default-by-family into by-variantSebastian Huber7-7/+0
Prefix the BSP family name with "bsps/" to make it distinct to the BSP variant names. Update #4468.
2021-07-15build: Use BSP family for optionsChris Johns7-0/+7
- Optionally add support for 'default-by-family' to allow option to be set by a family and so all related BSPs Close #4468
2021-02-26bsps: Add default rtems_get_target_hash()Sebastian Huber1-0/+1
Update #4267.
2020-09-14build: Alternative build system based on wafSebastian Huber14-0/+325
Update #3818.
