2023-05-20 | Update company name | Sebastian Huber | 1 | -1/+1 | |
The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | |||||
2022-08-22 | spec/bsps: Do not install tm27.h | Chris Johns | 1 | -1/+0 | |
Updates #4705 | |||||
2022-01-15 | bsps: Default to CPU counter benchmark timer | Sebastian Huber | 1 | -1/+1 | |
Most BSPs which used the stubbed benachmark timer provide a CPU counter. All BSPs provide at least a stub CPU counter. Simply use the benchmark timer implementation using the CPU counter. | |||||
2021-11-30 | build: Use common objects item for get memory | Sebastian Huber | 1 | -1/+0 | |
2021-02-26 | bsps: Add default rtems_get_target_hash() | Sebastian Huber | 1 | -0/+1 | |
Update #4267. | |||||
2020-09-14 | build: Alternative build system based on waf | Sebastian Huber | 1 | -0/+41 | |
Update #3818. |
