This enables the VME support for the MVME2500. Note that the PCIe
support from libbsd is used. So you need the related libbsd patches for
this to work.
If the drivers in libbsd are not enabled, the linker should not pick up
anything from this patch.
brains GmbH.
Propagate the group defined cppflags, cflags, and cxxflags from parent groups
to child items through the build item context.
Update #4670.
Update #3850
Update #3818.
