* | build: Merge default-by-family into by-variant | Sebastian Huber | 2021-08-18 | 5 | -5/+0 |
| | | | | | | | Prefix the BSP family name with "bsps/" to make it distinct to the BSP variant names. Update #4468. | ||||
* | build: Use BSP family for options | Chris Johns | 2021-07-15 | 5 | -0/+5 |
| | | | | | | | - Optionally add support for 'default-by-family' to allow option to be set by a family and so all related BSPs Close #4468 | ||||
* | spec: Remove RTEMS_NETWORKING options | Vijay Kumar Banerjee | 2021-04-07 | 2 | -18/+0 |
| | | | | Update #3850 | ||||
* | bsps: Add default rtems_get_target_hash() | Sebastian Huber | 2021-02-26 | 1 | -0/+1 |
| | | | | Update #4267. | ||||
* | bsps/powerpc: Remove -fno-common | Sebastian Huber | 2020-09-20 | 1 | -1/+0 |
| | | | | Remove -fno-common because it is the default since GCC 10. | ||||
* | build: Alternative build system based on waf | Sebastian Huber | 2020-09-14 | 9 | -0/+218 |
Update #3818. |
