* | bsps: Add default rtems_get_target_hash() | Sebastian Huber | 2021-02-26 | 1 | -0/+1 |
| | | | | Update #4267. | ||||
* | bsps/powerpc: Remove __ppc_generic define | Sebastian Huber | 2020-09-20 | 1 | -1/+0 |
| | | | | | | Do not force BSPs to define __ppc_generic. This was probably the last command line define in the BSPs. | ||||
* | bsps/powerpc: Remove -fno-common | Sebastian Huber | 2020-09-20 | 1 | -1/+0 |
| | | | | Remove -fno-common because it is the default since GCC 10. | ||||
* | build: Fix mghttpd01 test exclude | Sebastian Huber | 2020-09-17 | 2 | -17/+1 |
| | | | | Update #3818. | ||||
* | build: Alternative build system based on waf | Sebastian Huber | 2020-09-14 | 51 | -0/+1144 |
Update #3818. |
