path: root/spec/build/bsps/powerpc/mpc55xxevb/optclkemios.yml (unfollow)
2023-05-20Update company nameSebastian Huber1-1/+1
The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH.
2023-01-17build: Use enabled by for defaultsSebastian Huber1-9/+7
Merge the "default" and "default-by-variant" attributes. Use an "enabled-by" expression to select the default value based on the enabled set. This makes it possible to select default values depending on other options. For example you could choose memory settings based on whether RTEMS_SMP is enabled or disabled. The change was tested by comparing the output of ./waf bspdefaults before and after the change.
2023-01-17build: Replace variant patterns with a listSebastian Huber1-3/+3
Replace the variant patterns in the default-by-variant list with an explicit list of matching BSPs. The change was tested by comparing the output of ./waf bspdefaults before and after the change.
2021-08-18build: Merge default-by-family into by-variantSebastian Huber1-1/+0
Prefix the BSP family name with "bsps/" to make it distinct to the BSP variant names. Update #4468.
2021-07-15build: Use BSP family for optionsChris Johns1-0/+1
- Optionally add support for 'default-by-family' to allow option to be set by a family and so all related BSPs Close #4468
2020-09-14build: Alternative build system based on wafSebastian Huber1-0/+25
Update #3818.
