path: root/spec/build/bsps/powerpc/beatnik (follow)
* build: Use BSP family for optionsChris Johns2021-07-152-0/+2
| | | | | | | - Optionally add support for 'default-by-family' to allow option to be set by a family and so all related BSPs Close #4468
* bsps/powerpc, bsps/shared: Move remaining legacy networking header filesVijay Kumar Banerjee2021-06-231-3/+0
* powerpc/shared/console: Make console baud rate configurable.Peter Dufault2021-04-271-0/+2
| | | | | | | | | | | The "powerpc/shared/console" code has the start-up console value fixed at 9600 baud. This changes the hard-wired constant "9600" in the code to the configuration setting "BSP_CONSOLE_BAUD" and adds configuration support in both the "waf" and the legacy configuration systems. Note that the VME BSPs beatnik, mvme3100, and mve5100 can be improved by adding a "mvmexxxx" BSP family. This configuration change, as well as future configuration changes, could then be made in a "grp.yml" file.
* spec: Remove RTEMS_NETWORKING optionsVijay Kumar Banerjee2021-04-072-25/+0
| | | | Update #3850
* bsps: Add default rtems_get_target_hash()Sebastian Huber2021-02-261-0/+1
| | | | Update #4267.
* bsps/powerpc: Remove __ppc_generic defineSebastian Huber2020-09-201-1/+0
| | | | | | Do not force BSPs to define __ppc_generic. This was probably the last command line define in the BSPs.
* build: Alternative build system based on wafSebastian Huber2020-09-144-0/+163
Update #3818.
