2021-03-05 | spec: Move hypervisor start for use by AArch64 | Kinsey Moore | 1 | -0/+0 | |
AArch64 on hardware is often started at EL2 instead of EL1 from either u-boot or a first stage bootloader. This allows RTEMS to drop from EL2 execution to EL1 to operate as normal. | |||||
2020-12-10 | bsps/arm: Move BSP_START_IN_HYP_SUPPORT option | Sebastian Huber | 1 | -1/+2 | |
Clarify documentation. Update #4202. | |||||
2020-09-14 | build: Alternative build system based on waf | Sebastian Huber | 1 | -0/+15 | |
Update #3818. |
