* | build: Use BSP family for options | Chris Johns | 2021-07-15 | 1 | -0/+1 |
| | | | | | | | - Optionally add support for 'default-by-family' to allow option to be set by a family and so all related BSPs Close #4468 | ||||
* | spec: Move hypervisor start for use by AArch64 | Kinsey Moore | 2021-03-05 | 1 | -0/+16 |
AArch64 on hardware is often started at EL2 instead of EL1 from either u-boot or a first stage bootloader. This allows RTEMS to drop from EL2 execution to EL1 to operate as normal. |
