* | build: Fix the motorola_powerpc default baudrate | Chris Johns | 2021-07-15 | 1 | -2/+4 |
* | build: Use BSP family for options | Chris Johns | 2021-07-15 | 1 | -0/+1 |
| | | | | | | | - Optionally add support for 'default-by-family' to allow option to be set by a family and so all related BSPs Close #4468 | ||||
* | powerpc/shared/console: Make console baud rate configurable. | Peter Dufault | 2021-04-27 | 1 | -0/+5 |
| | | | | | | | | | | | The "powerpc/shared/console" code has the start-up console value fixed at 9600 baud. This changes the hard-wired constant "9600" in the code to the configuration setting "BSP_CONSOLE_BAUD" and adds configuration support in both the "waf" and the legacy configuration systems. Note that the VME BSPs beatnik, mvme3100, and mve5100 can be improved by adding a "mvmexxxx" BSP family. This configuration change, as well as future configuration changes, could then be made in a "grp.yml" file. | ||||
* | build: Alternative build system based on waf | Sebastian Huber | 2020-09-14 | 1 | -0/+23 |
Update #3818. |
