* | build: Add RTEMS_GCOV_COVERAGE option | Sebastian Huber | 2022-07-04 | 1 | -1/+1 |
| | | | | Update #4670. | ||||
* | build: Allow separate optimization flags | Sebastian Huber | 2022-07-04 | 1 | -0/+17 |
Allow separate optimization flags for the BSP, cpukit, and tests. For example, the BSP and cpukit may be built without optimization if coverage instrumentation is enabled, however, the tests may still use optimization. Update #4670. |
