* | leon,grcan: split out GRCAN non-FD specific support in separate file | Daniel Hellstrom | 2021-03-11 | 1 | -0/+1 |
| | | | | Close #4324. | ||||
* | leon,grcanfd: split out GRCANFD specific support in separate file | Daniel Hellstrom | 2021-03-11 | 1 | -0/+1 |
| | | | | Update #4324. | ||||
* | leon,can: introduce common CAN baud-rate calculation function | Daniel Hellstrom | 2021-03-11 | 1 | -0/+2 |
| | | | | | | | Reimplemented the baud-rate algorithm from scratch to cope with GRCAN, GRCANFD and OC_CAN devices. Update #4323. | ||||
* | build: Sort source lists | Sebastian Huber | 2021-02-24 | 1 | -4/+4 |
| | | | | Use the Python sorted() function to sort the "source" lists. | ||||
* | build: Alternative build system based on waf | Sebastian Huber | 2020-09-14 | 1 | -0/+142 |
Update #3818. |
