path: root/spec/build/bsps/mips/jmr3904 (unfollow)
2023-05-20Update company nameSebastian Huber4-4/+4
The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH.
2023-01-17build: Use enabled by for defaultsSebastian Huber2-6/+6
Merge the "default" and "default-by-variant" attributes. Use an "enabled-by" expression to select the default value based on the enabled set. This makes it possible to select default values depending on other options. For example you could choose memory settings based on whether RTEMS_SMP is enabled or disabled. The change was tested by comparing the output of ./waf bspdefaults before and after the change.
2023-01-17build: Add reason to test state definitionsSebastian Huber1-1/+4
2022-08-22spec/bsps: Do not install tm27.hChris Johns1-1/+0
Updates #4705
2021-11-30build: Use common objects item for get memorySebastian Huber1-1/+2
2021-08-18build: Merge default-by-family into by-variantSebastian Huber2-2/+0
Prefix the BSP family name with "bsps/" to make it distinct to the BSP variant names. Update #4468.
2021-07-15build: Use BSP family for optionsChris Johns2-0/+2
- Optionally add support for 'default-by-family' to allow option to be set by a family and so all related BSPs Close #4468
2021-02-26bsps: Add default rtems_get_target_hash()Sebastian Huber1-0/+1
Update #4267.
2020-09-14build: Alternative build system based on wafSebastian Huber4-0/+105
Update #3818.
