This driver has been tested with Micron NOR Flash via AXI Quad SPI.
When committed, the MicroBlaze RAM size was hard-coded to 16MB. This
changes the default to 256MB and sets the KCU105 BSPs to 2GB since that
is what the board has on it.
This patch adds a vector for debug events along with a hook similar to
the exception framework. The debug vector generates an exception frame
for use by libdebugger.
This patch updates the CPU_Exception_frame to include all necessary
registers, combines hardware snd software exception handlers into a
shared vector, provides an architecture-specific hook for taking
control of exception handling, and moves exception handling over to
actually using the CPU_Exception_frame instead of a minimal interrupt
stack frame. As the significant contents of _exception_handler.S have
been entirely rewritten, the copyright information on this file has been
updated to reflect that.
This includes fixes and improvements necessary to get libbsd networking
running.
This reworks the existing MicroBlaze architecture port and BSP to
achieve basic functionality using the latest RTEMS APIs.
