path: root/spec/build/bsps/m68k/mvme147s (follow)
* build: Use common objects item for get memorySebastian Huber2021-11-301-1/+2
* build: Merge default-by-family into by-variantSebastian Huber2021-08-181-1/+0
| | | | | | | Prefix the BSP family name with "bsps/" to make it distinct to the BSP variant names. Update #4468.
* build: Use BSP family for optionsChris Johns2021-07-151-0/+1
| | | | | | | - Optionally add support for 'default-by-family' to allow option to be set by a family and so all related BSPs Close #4468
* bsps: Add default rtems_get_target_hash()Sebastian Huber2021-02-261-0/+1
| | | | Update #4267.
* build: Alternative build system based on wafSebastian Huber2020-09-143-0/+92
Update #3818.
