* | Update company name | Sebastian Huber | 2023-05-20 | 1 | -1/+1 |
| | | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | ||||
* | spec/bsps: Do not install tm27.h | Chris Johns | 2022-08-22 | 1 | -1/+0 |
| | | | | Updates #4705 | ||||
* | build: Use common objects item for get memory | Sebastian Huber | 2021-11-30 | 1 | -1/+2 |
* | spec: Remove RTEMS_NETWORKING options | Vijay Kumar Banerjee | 2021-04-07 | 1 | -2/+0 |
| | | | | Update #3850 | ||||
* | bsps: Add default rtems_get_target_hash() | Sebastian Huber | 2021-02-26 | 1 | -0/+1 |
| | | | | Update #4267. | ||||
* | build: Alternative build system based on waf | Sebastian Huber | 2020-09-14 | 1 | -0/+55 |
Update #3818. |
