path: root/spec/build/bsps/lm32/lm32_evr (unfollow)
2023-05-20Update company nameSebastian Huber6-6/+6
The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH.
2023-01-17build: Use enabled by for defaultsSebastian Huber2-7/+8
Merge the "default" and "default-by-variant" attributes. Use an "enabled-by" expression to select the default value based on the enabled set. This makes it possible to select default values depending on other options. For example you could choose memory settings based on whether RTEMS_SMP is enabled or disabled. The change was tested by comparing the output of ./waf bspdefaults before and after the change.
2022-08-22spec/bsps: Do not install tm27.hChris Johns1-1/+0
Updates #4705
2022-07-04build: Fix optimization flags definition orderSebastian Huber2-4/+4
OPTIMIZATION_FLAGS must be defined before /build/bsp/bspopts is processed. Update #4670.
2022-07-04build: Add cppflags, cflags, cxxflags to groupsSebastian Huber1-0/+3
Propagate the group defined cppflags, cflags, and cxxflags from parent groups to child items through the build item context. Update #4670.
2021-11-30build: Use common objects item for get memorySebastian Huber2-1/+2
2021-08-18build: Merge default-by-family into by-variantSebastian Huber2-2/+0
Prefix the BSP family name with "bsps/" to make it distinct to the BSP variant names. Update #4468.
2021-07-15build: Use BSP family for optionsChris Johns2-0/+2
- Optionally add support for 'default-by-family' to allow option to be set by a family and so all related BSPs Close #4468
2021-04-07spec: Remove RTEMS_NETWORKING optionsVijay Kumar Banerjee2-18/+0
Update #3850
2021-02-26bsps: Add default rtems_get_target_hash()Sebastian Huber1-0/+1
Update #4267.
2020-09-14build: Alternative build system based on wafSebastian Huber7-0/+153
Update #3818.
