path: root/spec/build/bsps/i386 (follow)
* build: Use BSP family for optionsChris Johns2021-07-1516-0/+16
| | | | | | | - Optionally add support for 'default-by-family' to allow option to be set by a family and so all related BSPs Close #4468
* spec: Remove RTEMS_NETWORKING optionsVijay Kumar Banerjee2021-04-072-21/+0
| | | | Update #3850
* bsps: Add default rtems_get_target_hash()Sebastian Huber2021-02-261-0/+1
| | | | Update #4267.
* build: Fix multiple defintion error for i386/pc386Sebastian Huber2020-09-151-4/+9
| | | | | | Make the objcopy an bld.objects() task generator. Close #4079.
* build: Fix i386/pc386 link of SMP start fileSebastian Huber2020-09-151-1/+1
| | | | Update #3818.
* build: Add RELOCADDR to i386/pc386 optionsSebastian Huber2020-09-152-0/+29
| | | | Update #3818.
* build: Fix i386/pc386 ABI flagsSebastian Huber2020-09-151-5/+0
| | | | Update #3818.
* build: Fix i386/pc386 with SMP enabledSebastian Huber2020-09-153-1/+52
| | | | Update #3818.
* build: Alternative build system based on wafSebastian Huber2020-09-1432-0/+709
Update #3818.
