* | build: Merge default-by-family into by-variant | Sebastian Huber | 2021-08-18 | 16 | -16/+0 |
| | | | | | | | Prefix the BSP family name with "bsps/" to make it distinct to the BSP variant names. Update #4468. | ||||
* | build: Use BSP family for options | Chris Johns | 2021-07-15 | 16 | -0/+16 |
| | | | | | | | - Optionally add support for 'default-by-family' to allow option to be set by a family and so all related BSPs Close #4468 | ||||
* | spec: Remove RTEMS_NETWORKING options | Vijay Kumar Banerjee | 2021-04-07 | 2 | -21/+0 |
| | | | | Update #3850 | ||||
* | bsps: Add default rtems_get_target_hash() | Sebastian Huber | 2021-02-26 | 1 | -0/+1 |
| | | | | Update #4267. | ||||
* | build: Fix multiple defintion error for i386/pc386 | Sebastian Huber | 2020-09-15 | 1 | -4/+9 |
| | | | | | | Make the objcopy an bld.objects() task generator. Close #4079. | ||||
* | build: Fix i386/pc386 link of SMP start file | Sebastian Huber | 2020-09-15 | 1 | -1/+1 |
| | | | | Update #3818. | ||||
* | build: Add RELOCADDR to i386/pc386 options | Sebastian Huber | 2020-09-15 | 2 | -0/+29 |
* | build: Fix i386/pc386 ABI flags | Sebastian Huber | 2020-09-15 | 1 | -5/+0 |
* | build: Fix i386/pc386 with SMP enabled | Sebastian Huber | 2020-09-15 | 3 | -1/+52 |
* | build: Alternative build system based on waf | Sebastian Huber | 2020-09-14 | 32 | -0/+709 |
Update #3818. |
