* | bsps: Default to CPU counter benchmark timer | Sebastian Huber | 2022-01-15 | 1 | -1/+1 |
| | | | | | | Most BSPs which used the stubbed benachmark timer provide a CPU counter. All BSPs provide at least a stub CPU counter. Simply use the benchmark timer implementation using the CPU counter. | ||||
* | build: Use common objects item for get memory | Sebastian Huber | 2021-11-30 | 2 | -1/+2 |
* | bsps/arm: Fix ABI flags for Cortex-M4 | Sebastian Huber | 2021-09-14 | 1 | -1/+3 |
| | | | | Close #4504. | ||||
* | build: Merge default-by-family into by-variant | Sebastian Huber | 2021-08-18 | 18 | -18/+0 |
| | | | | | | | Prefix the BSP family name with "bsps/" to make it distinct to the BSP variant names. Update #4468. | ||||
* | build: Use BSP family for options | Chris Johns | 2021-07-15 | 18 | -0/+18 |
| | | | | | | | - Optionally add support for 'default-by-family' to allow option to be set by a family and so all related BSPs Close #4468 | ||||
* | bsps: Add default rtems_get_target_hash() | Sebastian Huber | 2021-02-26 | 1 | -0/+1 |
| | | | | Update #4267. | ||||
* | build: Add test excludes for rcxx01 | Sebastian Huber | 2020-10-10 | 1 | -0/+1 |
* | build: Alternative build system based on waf | Sebastian Huber | 2020-09-14 | 22 | -0/+484 |
Update #3818. |
