Update #4982.
Hi all, this is my first email patch submission and my first contribution to RTEMS, so please give any
feedback you have!
This patch enables interrupt driven data reception on USART ports on
STM32F4 series chips. This feature is gated behind the config flag
BSP_CONSOLE_USE_INTERRUPTS. If this flag is not set to True, the older
polling implementation will be used. I tested this feature on STM32F401CE
(blackpill) and STM32 Nucleo F411RE boards, with both capable of keeping
up with a 115200 baud continous data stream. With the older polling
implementation, both would drop bytes at 9600 baud. In addition, I
updated the implementation of usart_set_attributes to support changing
the baud rate of the USART port based on the input speed.
brains GmbH.
Merge the "default" and "default-by-variant" attributes. Use an
"enabled-by" expression to select the default value based on the enabled
set. This makes it possible to select default values depending on other
options. For example you could choose memory settings based on whether
RTEMS_SMP is enabled or disabled.
The change was tested by comparing the output of
./waf bspdefaults
before and after the change.
Replace the variant patterns in the default-by-variant list with an
explicit list of matching BSPs.
./waf bspdefaults
Updates #4705
OPTIMIZATION_FLAGS must be defined before /build/bsp/bspopts is processed.
Update #4670.
Propagate the group defined cppflags, cflags, and cxxflags from parent groups
to child items through the build item context.
Update #4670.
Most BSPs which used the stubbed benachmark timer provide a CPU counter.
All BSPs provide at least a stub CPU counter. Simply use the benchmark
timer implementation using the CPU counter.
Close #4504.
Prefix the BSP family name with "bsps/" to make it distinct to the BSP
variant names.
Update #4468.
- Optionally add support for 'default-by-family' to allow
option to be set by a family and so all related BSPs
Close #4468
Update #4267.
Update #3818.
