path: root/spec/build/bsps/arm/optgtfreq.yml (follow)
* build: Merge default-by-family into by-variantSebastian Huber2021-08-181-1/+0
| | | | | | | Prefix the BSP family name with "bsps/" to make it distinct to the BSP variant names. Update #4468.
* build: Use BSP family for optionsChris Johns2021-07-151-0/+1
| | | | | | | - Optionally add support for 'default-by-family' to allow option to be set by a family and so all related BSPs Close #4468
* arm/fvp: New BSPSebastian Huber2020-12-231-1/+4
| | | | | | | | This BSP supports the Arm Fixed Virtual Platform. Only the Cortex-R52 processor configuration is supported by the BSP. It should be easy to add support for other variants if needed. Update #4202.
* bsps/arm: Unify ARM Generic Timer optionsSebastian Huber2020-12-101-0/+16
Update #4202.
