path: root/spec/build/bsps/arm/optgiccpuif.yml (follow)
* arm/fvp: New BSPSebastian Huber2020-12-231-0/+19
This BSP supports the Arm Fixed Virtual Platform. Only the Cortex-R52 processor configuration is supported by the BSP. It should be easy to add support for other variants if needed. Update #4202.
