Most BSPs which used the stubbed benachmark timer provide a CPU counter.
All BSPs provide at least a stub CPU counter. Simply use the benchmark
timer implementation using the CPU counter.
Prefix the BSP family name with "bsps/" to make it distinct to the BSP
variant names.
Update #4468.
Update #4468.
- Optionally add support for 'default-by-family' to allow
option to be set by a family and so all related BSPs
Close #4468
Calling the memory FLASH and EXTRAM instead of FLEXSPI and SDRAM makes
it simpler to support other types of external RAM. This patch also
removes some of the calculations and improves names and documentation to
avoid pitfalls. It removes a unnecessary memory definition.
Update #4180
Update #4180
The sizes are configurable via fuses or per software via some registers.
At the moment the registers are not changed. Changing the registers
destroys data stored in the RAM areas (like application code or data).
So either the fuses or some bootloader should be used to set them before
the application starts.
This also adds an OCRAM only linker command file.
Update #4180
Update #4267.
Use the Python sorted() function to sort the "source" lists.
Move the Freescale EDMA driver to it's own object and build it only for
the BSP that is currently using it.
This allows an application to get the registers of the LPSPI. That is
usefull for applications that want to use DMA for a very specialized and
highly optimized communication.
Update #4180
Note: The changes have been done with portability in mind. The driver
should (in theory) be able to replace the original one in the MPC BSPs
too. For full compatibility an adaption layer and especially a test
would be necessary. Because both are missing, don't integrate it into
the MPC BSP now.
Update #4180
When moving the headers from the imx BSP to the shared area, the wrong
directory has been selected. This patch fixes that problem.
Update #4180
This allows simpler creation of own dts files for custom boards.
Update #4180
Update #4180
