* | build: Use BSP family for options | Chris Johns | 2021-07-15 | 1 | -0/+1 |
| | | | | | | | - Optionally add support for 'default-by-family' to allow option to be set by a family and so all related BSPs Close #4468 | ||||
* | bsps/shared: Adapt fsl-edma driver for imxrt | Christian Mauderer | 2021-01-21 | 1 | -0/+16 |
Note: The changes have been done with portability in mind. The driver should (in theory) be able to replace the original one in the MPC BSPs too. For full compatibility an adaption layer and especially a test would be necessary. Because both are missing, don't integrate it into the MPC BSP now. Update #4180 |
