path: root/spec/build/bsps/arm/fvp (follow)
* build: Fix broken linkSebastian Huber2021-03-091-1/+1
* bsps: Add default rtems_get_target_hash()Sebastian Huber2021-02-261-0/+1
| | | | Update #4267.
* arm/fvp: New BSPSebastian Huber2020-12-2311-0/+316
This BSP supports the Arm Fixed Virtual Platform. Only the Cortex-R52 processor configuration is supported by the BSP. It should be easy to add support for other variants if needed. Update #4202.
